BDGiven
- Aug 3, 2018
- Wadsworth, OHIO USA
Hello, I'm fairly new to the site and have been reading up on making a RPC.
There are many plans out there for 5hp and up idlers. I'm using a 3hp 3 phase to power a 2hp Bridgeport Series 1 CNC. I'm going with cheap and easy as I'm not looking to make parts on this machine. I just need it to run so I can sell this one. I have another identical machine that will get a full rebuild. I don't plan on needing the RPC for that one.
This is all for the joy of learning something new, so please don't be going off on me about wasting my time with junk! It's my time! I work full time managing a gage lab and enjoy making things work in my spare time. Cars, Jeeps, Bikes (street & dirt) 4 wheelers, Personal Watercraft, Arduino projects. Now CNC! Starting with an RPC.
With that out of the way I'll get around to my project.
I'm leaning toward the Fitch design.
I have a Jacobs 3hp 3 phase motor wired for the low voltage setting.
First I thought I would need a base reading so; one leg to 3-9, and the other to 1-7, with 2-8 to be the generated leg. Rope start the motor and throw on the power.
generated leg to Black = 209V, to Red = 198V, to Neutral = 166
Measuring the other two legs with it running read the stock incoming voltages of B/R = 233 and 113/119 to neutral.
Since this is such a small idler I planned to use a SPP6 Hard Start kit as the potential relay and start cap. SPP6 Hard Start Capacitor for Supco Relay 1/2HP-1 HP | eBay
The run capacitors have me stumped. I've read that anything over 250V will work (preferably oil filled) but the amount/value of microfarads required to balance each leg would be helpful. All the balancing posts I've read are a little vague on how much cap is needed to raise a certain voltage. There's no store round here to just go buy caps, and I don't want to buy a pile of various sizes and "hunt & peck" to find what works.
Does anyone have the values or the formula to balance these readings?
The power running to my barn is 2 hot legs and a ground as neutral, with a separate ground rod staked at the barn. I was told this is common, but so is DEATH!
I read of the control transformer trick to get a real neutral that's not also the ground and I made one up. Is this a valid method? Or should I look into running a Neutral to the barn?
Thanks in advance for any helpful information. I take constructive criticism as helpful, especially concerning high voltage!
