Rob F.
- Aug 5, 2012
- California, Central Coast
I am finally getting around to wiring up a step up transformer to run some 480 only equipment. I have wired it in and want to make sure the voltages are reasonable. I had to move the tap wire to the #1 lug, that is the one shown to have the highest input volts, but I am concerned the output volts might still be to high.
Line power is 241-242 volts at RPC.
Out of RPC at input of transformer is X1-X2= 281v, X1-X3= 263v, X2-X3= 240v. X1 is the generated leg. out of transformer: H1-H2= 497v, H1-H3= 542v, H2-H3= 463v.
It is a 15hp RPC and a 15kva HPS step up transformer, model SG3A0015DK, if it matters.
Voltage readings with no load, loads would be 3 or 5 hp motors.
A second question is about grounding, I did some looking at it was not clear to me what should and should not be grounded and should the low 240 ground be separate or connected to the 480 ground, I wired the ground lug in the transformer frame to the 240 input ground wire. No ground on the 480 side right now, I was pretty sure the 230 and 480 grounds should not be connected together but want to double check before getting to far along.
