Clausing drill press 480 to 240?
Likes Likes:  0
Results 1 to 8 of 8
    Aug 2019
    Ohio
    7
    Default Clausing drill press 480 to 240?
    4928aec9-561b-42ec-bf75-957726f6c1db.jpg25c4fc7f-76d1-4e36-a012-06bb29df5af7.jpgb2b94f95-14d2-4537-92cb-2695476f3bac.jpgfadef196-7dc7-4e30-9d87-4d04760e5d35.jpgI bought this gang drill on a cast iron base, thinking i could change it to 240v and use in my barn. I looked at motor wiring, found the directions (9 wires),,no problem. It has a switch to go to tap mode, then use foot switch to reverse.
    I found a transformer in the elect cabinet that shows putting a jumper to go to 240, but then the rest of that stuff in there, wow!
    Is the motors and the transformer all i do? I have no idea what most of that stuff does.
    Jan 2017
    Washington
    197
    54
    If it looks like gobblygook on the inside instead of transformers, contactors, etc, then I would recommend getting an electrician to convert it to 220v 3ph for you. It’s not super cheap, but if your time has a value greater than $0/hr, the couple hundred bucks to have someone else do it might be worth it. It might be even cheaper because you can bring the DP to the electrician.
    Aug 2019
    Ohio
    7
    Naw,,,that sounds too easy. Anybody could do that. I could rip all that stuff out and wire straight to motors for 240, but it sounds like more fun to try and make it all work with the pedals and stuff.
    Jan 2017
    Washington
    197
    54
    The recommendation of an electrician was an attempt to have you keep all the bells and whistles. That box looks professionally wired and it shouldn’t take them long to convert it.
    Aug 2019
    Ohio
    7
    That would defeat the purpose of this forum. I have time and i can learn.
    Jul 2014
    MI USA
    877
    197
    362
    Quote Originally Posted by Jonwick View Post
    If the point is to learn, then I would put it back to how it was and run it at 480V.
    Learn how it was designed to operate, with it's PLC control and tapping function, Do you need or desire the features it has, does it function correctly?
    You can create a 480 supply from a 230 supply, with a couple small 1Φ transformers. Now that's learning.
    Then you can decide what to do from there.
    Whoops, loaded the wrong version
    SAF Ω
    Aug 2019
    Ohio
    7
    I don’t want to make 480. I want to change this drill press to 240v.
    Aug 2019
    Ohio
    7
    Well, i guess i will figure it out and come back to teach you guys! Lol,,,
