Folks, have any of you had experience with a CNC connected to an RPC which uses dynamic braking? I just spoke with a tech guy at GWM about sizing up a unit for my Mazak Slant 15 (circa 81) and he unloaded that potential problem on me.
It seems that many of the Mazaks are/were notorious for dumping power back into the line when braking engages and there is nowhere for this excess power to go. He said that since the RPC is in close proximity to the machine, it will simply bounce the power back, resulting in adverse effects to the computer (error codes, shutting down, etc.).
I found limited info to this phenomena, or how to deal with it. Some mentioned a power resistor but that was with drive motors of 1-2hp. I'm dealing with 15hp driving my chuck. I also read somewhere about using a heating element, but I believe it was also referencing a small motor situation.
If any of you have info/insight into dealing with this I'd be elated if you could share it.
Best,
Mark
Best,
Mark
