I know it's a taboo subject and one doesn't know unless they ask.
Beginning a DIY machine retrofit using off the shelf components. I have 220V 1P 4 wire supply HHNG (it's in a home, not industrial).
The components which power and control the machine use both 220 and 110 1P. In order to supply power to the 110 stuff, is it fine just to pull from one leg of the 220 or install a control transformer (I figure the transformer is the correct answer but wondering if the other option is fine for personal use)? The 110 is for powering things like the PC/monitor, 24V power supply, CNC board, stepper drives, case fans (pretty much everything except the VFD). 110 might draw 10A. The 7.5HP VFD will be derated so one leg will draw more current than the other so figure I pull the 110 devices from the non-derated leg.
Everything goes through a respective breaker and then the main breaker/disconnect on the enclosure.
If I am wrong, explain to me the why so I can understand instead of berating me without an explanation.
Thanks.
Thanks.
