Contactor Sizing - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    May 2021
    Virginia
    345
    374
    88
    Regarding the original post... a 1.5HP motor should only pull 1.5HP or (745.7W per HP * 1.5 is 1,118.55W). I'm not an electrical (insert profession) and don't claim to be (refer to Just a Sparky and JST - I ain't learnt none that stuff proper, just hard knocks and a little reading.) Anyway, if you need a switch for a 1.5HP motor, get that. If the VFD says it wants 15A, get that. Heck, as long as it isn't a crazy difference in cost, I would buy the higher amp switch, anyway. It aught to last longer (especially with a lighter load).
    Sent by telegraph using - .- .--. .- - .- .-.. -.-
  2. #22
    Virginia
    22,062
    7561
    12694
    Quote Originally Posted by 52 Ford View Post
    Yah, really.. The heavier goods can actually be CHEAPER!
    And it isn't as if you had to feed a production line with a large number of identical parts, and shave fifty-cents a unit, anyway, is it?
    Ex:
    1 each NIB Arrow Hart Contactor # ACC330UM10, 3 Pole, 600V, 40 Amps, 24 vac Coil ITEM PRICE: US $17.00
    2 each NIB Duracool 30 Amp were $17.98 each.
    The NIB 125 A Fuji was still only $70.
    "etc."
    "Remaindered" former stale stock or shelf-spares as onesies and fewsies of top specification from decent manufacturers are all over the place, cheap and cheerful.
    Grab some and adapt.
    NNN
  3. #23
    May 2020
    Minnesota
    578
    239
    245
    Are we talking bridge contractors or mercury relays here? Durakool is mostly known for their mercury relays. $18 each for a 30 amp mercury relay that will last more or less forever is a pretty smoking deal. Especially if one has an inductive DC load to switch often.
    ...As long as you don't have to pay to dispose of them at end of life and they do in fact end up in haz-mat where they belong instead of landfill like so many mercury thermostats, PCB capacitors, etc.
    Cradle-to-grave engineering, basic ecological responsibility and all that.
  4. #24
    Virginia
    22,062
    7561
    12694
    Quote Originally Posted by Just a Sparky View Post
    Nah. Not Hg displacement on those. Conventionals. Basic HVAC market goods, Mexican factory.
    A lot of these 'vanilla' goods are made in India as well.
    Buying from China is avoidable. Let's go Brandon.
    They do and I do and I have a stash. But Mercury displacement units are typically $60 or so, and not as easy to find, NOS, major-maker.
    In any case.. for DC, an SCR bridge matrix under "4Q" DC Drive control - or Crydom SSR "H" bridge - is better yet.
    Single-phase especially, I've been using Crydom SSRs since the dawn of the 1970's.
    No contactors at all, no arc at all, no braking resistors, either, vs clunky contactors with controlled & quenched arc.
    I did say NO arc?
    Also less space, fewer wires, easier control, neat, clean, and effective.
    What's not to like about that?
  5. #25
    May 2021
    Virginia
    345
    374
    88
    Let's go Brandon.
    Amen.
  6. Likes Just a Sparky liked this post
