Mr.Green
Cast Iron
- Apr 20, 2011
- NE Indiana
Working on an Italian machine, 4 motors run the 5 heads, motor for feed beam up/down and one motor for the feed.
Everything works except the feed. Feed has two sets of jog buttons forward/reverse, a test/auto switch and the start and stop buttons.
Everything on the machine works, except the feed. I can push in contacters and feed motor runs in either direction.
Found all 3 limit switches which I believe are tied to the feed, had no continuity when in the NC position. Overnighted 3 new pizzato switches, installed, no difference. Replaced aux contactors on the two starters, no difference.
Finally pulled the pushbutton panel and checked voltages on the stop buttons and on one side of start buttons. All are correct at 120v (480v machine, 120v controls) except for all the ones in the feed circuit. I read voltages from 20 to 30v on those.
Obviously I found the issue.
But, my question is, what could cause this?
I have seen this with control transformers wired wrong, but this issue is just on the feed.
Everything else functions correctly.
Is it a almost broken wire somewhere in the machine (probably inside one of the pieces of liquid tight conduit) voltages read exactly right on all circuit breakers in the control panel.
I guess I need to find my really long leads I made up and start checking ends of wires in that circuit.
Any guesses? Something obvious I'm overlooking?
All components are Klockner moeller, so plastic IEC stuff, but at least what I consider good IEC stuff.
All the pushbuttons are making contact and working as they should.
Sorry, don't have a picture of panel, but for being 30 years old, it's nice a tidy and other than being switched from 230 to 460 no one has messed with it, or if they did they obviously cared about their work.
Sent from my SM-G998U using Tapatalk
