Welder6131
- Nov 8, 2011
- Ohio, USA
Just hooked up my RPC and I'm getting 240 on legs 1 and 2 and leg 3 is fluctuating between 234 and 255V. Cleaned my motor starter contacts and checked my transformer output which was about 125v on my lathe. I have to manually push my contactors in to get the magnetic starter to engage, but lathe motor will only run for a few minutes before kicking out. Double checked motor wiring which was good. If I press the start stop buttons I get nothing.
Where Do I go from here, would motor heaters cause this?
