Parker1320
- Sep 30, 2018
I just purchased a Dake Mep Tiger 350 cold saw that is 3 phase. I will be connecting a VFD which I have no problem installing and programming. My question comes to the coolant pump and the switch that is connected to the blade handle. I believe that I can connect the handle connections straight to the VFD to S1 and S2. The next question concerns the coolant pump. With the VFD being connected straight to the motor, there would be no power to the coolant pump. I have not checked yet but all indications show that it is 3ph also. So connecting the pump to the VFD maybe possible but how would this turn on and off. Would the handle switch kick this in or would I have to wire it seperate to another VFD. The power lead is currently in a transformer box.
