Delta VFD CP2000 connection via ethernet
Likes Likes:  0
Results 1 to 2 of 2
    Apr 2020
    ARGENTINA
    Default Delta VFD CP2000 connection via ethernet
    Hey good day everyone.
    I'm trying to connect 2 Delta VFD CP-2000 using CMC-MOD01 modules to connect them to the router and manage them from the PC and or PLC
    By now, Delta DCI soft recognizes both of the modules without any problem. In fact I can see all the parameters of both of the VFDs using the monitor, its assigned IPs.
    Problem is when trying to use VFDsoft, as it needs COM address and its parameters but I don't have them, and I don't know if I'm missing any other component in order to make it work.
    Ethernet
    |--PC
    |--PLC
    |--CMC-MOD101---VFD CP-2000(1)
    |--CMC-MOD101---VFD CP-2000(2)
    Dec 2019
    NEW ZEALAND
    131
    27
    COM address likely means it's still trying to connect via serial. There might be an option for what type of connection to try and make?
