Can anyone help, this is causing me deep distress!
I have DSG 1330 toolroom lathe, 7.5 hp motor, I have no 3 phase but have aquired a 7.5kw rotary inverter which I did not use due to later reading that it would not be suitable to run the lathe. I then bought a jaguar 11kw digital inverter as advised only to find that wouldn't do the job either as it's designed to run a motor only not to pull contactors in and run motor. It doesn't run motor alone either.
Can anyone suggest any options to get me out of this ever increasing money pit of useless electrical equipment I seem to be collecting?
As I bought the rotary inverter dismantled I would also like any info on re commecting cables in correct order.
