No. Nothng extra. "Idler", not load. Stiil a "starting" load, though. The "primary" is already online and delivering 3-P. Only needs a suitable contactor. Manually operated, ELSE staggered start, so one COULD add a TD relay or any of several other "sensorish" means.
CAN it use caps? "Tuning" can still improve performance of the net-larger RPC "coalition", but ordinarily only if it is to be used for the same load, majority of the time.
Not to forget you still have that net TOTAL load applied to the 1-P supply, so starting a 1 HP or 2HP, , then dropping four more onto line in succession isn't going to gain much.
That IS close to what happnes if instead of a besoke supplementary idler, one just goes 'round switching ON, but NOT loading-up every 3-P motor on that idler's output, though.
Makes more sense at 10+10, or 10+7.5, or 10+5, 7.5+7.5, 5+5. etc.
Probably fire-up that SAG right smartly with a 10 HP primary idler and control for it, drop another ten online, then drop it back off once the lathe is uo "on step", if the work of the day is light or medium. Leave it in only when pushing hard and furious-like.
