I have a Goodway Taiwan 16 inch lathe with a destroyed electrical system. I got it with the intention of changing out the motor, as I only have single phase power. I pulled the motor, and have no idea whether it works or not.
I am not an electric-oriented person.
Here is the plate from the motor:
Here is the electric panel, the reason the lathe was scrapped:
Anyway, I appreciate that I am way behind the knowledge curve here, but figured that somehow, I should be able to get a motor rigged with the original pulley system and get the otherwise functional lathe to run. Even if the HP and speed do not match original specs.
Anyway, I guess I am asking generally where do you suggest I start? I assume there are test procedures for the motor, and if it functions, I need to decide if it is better to try to modify my electric system, or just go for a whole new motor, with simplified wiring.
