Bill D
- Apr 1, 2004
- Modesto, CA USA
I went to use my skilsaw yesterday. It works fine then i had to add an extension cord to reach. Plugged in the cord with the saw attached. No problem, no tripping. Then I went. Pulled the trigger and the GFCI tripped off. Tried it several times, several different ways. Ended up using. a different GFCI outlet and a different cord to get the job done.
So I guess the cord is bad. Probably a fault to ground from the hot leg. But not at 120 volts only at 120 volts with a large amp draw. I have seen bad fuses that check good on the meter but will not pass the amps needed. I would think an intermittent short would be more with no load to draw off amps? Any ideas on what is wrong so it passes the GFCI test except under load. I thought GFCI detected miliamp imbalances.
Bill D
Bill D
