fitch williams 10 hp converter
Likes Likes:  0
Results 1 to 14 of 14
    Aug 2005
    pa.
    22
    Post
    hey all,
    i mostly am a lurker here , but i need a little help. getting ready to construct a converter per fitch williams 10 hp design, but i been studying this schematic for days, and i do not understand how the start caps are switched out using the switches that are called out in the parts list. it would make sense (to me anyway) if S2 was a momentary contact switch. what am i missing here ? oh by the way, you guys have already been a big help to me, even if you didn't know !
    thanks kindly
    levi
    Aug 2005
    Kingsport, TN
    1,269
    5
    72
    Post
    I have the Fitch Williams 10 hp converter schematic and parts list. I believe there is a mistake in the parts list. The description for S1 and S2 are interchanged. S1 should be the maintened pull on / push off mushroom head switch and S2 should be a momentary switch. I have been building converters for more than 15 years but I use a potential relay to drop the start capacitors from the circuit. I think Fitch's circuit will work fine and I do use his balancing technique. In fact, the last converter I worked on would start without the starting circuit once the phases were balanced. I managed to get the phases to within 3% when operating a motor of the same horsepower as the idler.
    Aug 2005
    pa.
    22
    Post
    toolnut, thank you kindly
    Now i can see it, that makes a world of difference. boy do i feel dumb now, that is so simple and right there, talk about not being able to see the forest for the trees ! anyhow I certainly appreciate that. got the motor, contacters,switches and all just got to pickup an enclosure and i'll be set. have a smaller converter (3hp)now , but it has no balancing caps, and i need a bigger converter anyhow.
    thanks levi
    Aug 2004
    Arlington, TX
    169
    Post
    Where can I get Fitch Williams design and parts list? I have a need to build a 10 hp RPC. Or, dose anyone have a good proven design for a 10 hp converter?
    Tom
    Aug 2005
    pa.
    22
    Post
    hey dude,
    here is where i found it http://www.practicalmachinist.com/FitchWConverter.pdf
    later levi
    Jul 2005
    24
    Post
    Can anyone tell me how many amps the converter draws under no load?
    Nov 2004
    colorado
    122
    Post
    Under no load it only has to overcome its own windage and friction. Fitch told me once but I forget- it was about as much as a 100 watt light bulb. Not very much at all.
    jhg
    Apr 2005
    south texas
    97
    Post
    A generic idle current for a 10 HP motor is about
    7 amps. Motor construction will determine the true
    idle current, as will the phase relationships
    between poles, and the terminal voltage. And unless
    properly balanced, you need to add/subtract the cap
    currents.
    But it's a bit more than a 100W bulb. <g>
    <als>
    Aug 2004
    Arlington, TX
    169
    Post
    Anybody have pictures of their up and running Fitch Williams 10 HP converter? I.E., how the componets are breadboarded. Please post or e-mail me direct. Thanks for any input.
    Tom
    Nov 2019
    New York
    T. Overeynder did anyone ever get you pictures? I know this its an old thread but I'm. looking for a "Fitch Williams for dummies" diagram somewhere. I'm not educated on ladder diagrams and the connecting points are confusing when not familiar. I'm an electrician for retail commercial and not used to anything in controls. any photos or simple diagrams would be appreciated. I've read a million posts and watched videos but now I'm looking for a simple photo and/ or diagram to get my head around it. Not looking to veer from Fitch's design as a friend of mine used to have one made from his design and it worked flawlessly for years till he sold off for retirement. I've used VFDs and they're fine but with a new shop layout id like a one piece solution the 3 phase issue. I have all the parts I believe and even dug up an old 96 Grainger Catalog to cross reference to ensure I wasn't getting something re numbered. I added an overload and a few more indicators as well as digital displays to see the balance as I had a few kicking around. just looking to wire exactly to Fitch's intent. Thanks
  11. #11
    Feb 2004
    peekskill, NY
    24,476
    4576
    [QUOTE=fsmyth;343542]A generic idle current for a 10 HP motor is about
    7 amps.
    That's the amp-clamp number. Most of that current is reactive and will not spin
    a residential watt-hour meter. A 5 hp converter draws about 140 watts of real power
    at idle. One could expect a 10 hp one to draw about twice that.
  12. #12
    Virginia
    27,784
    7561
    8635
    Quote Originally Posted by Adrian Williams View Post
    Sounds like you are making a problem out of a solution.
    Fitch furnished a simple schematic, parts list, theory of operation and instructions as a .pdf. It is referenced from within PM's "stickies", top of this forum:
    https://www.practicalmachinist.com/FitchWConverter.pdf
    10 HP. Because it is a good size. And because it scales easily to any other idler size.
    The only "ladder" fu a body might need is to mount the bugger in his attic for lack of shop floorspace?
    PS: Useful numbers, Jim. Thanks for that.
  13. #13
    Feb 2004
    peekskill, NY
    24,476
    4576
    Those numbers were from my stone age converter, no capacitors were harmed in its construction.
    At the same that I borrowed a digital scope from work to check the waveform balance, I used a non-inductive
    ten ohm resistor to plot the current and voltage being supplied from the utility phase on this system.
    I think the number basically came from the amp clamp reading, adusted for the apparent phase angle
    between voltage and current waveforms. Phase angle difference between current (green) and voltage (red)
    Setup photos. Very scary. Don't do this. The fused knife switch is on the wall above the oak toolbox,
    current and voltage leads tagged into this and lead to the measurement setup:
    Yeah, definitely do not do this. At least not this way. The gold item under the mallet is the non-inductive
    resistor, the smaller resistors are 10 megs that go in series with the one meg scope probes to give a 100X probe.
    I seem to recall I measured 120 watts in one way, and 140 in another. The 140 was the amp clamp reading times
    the phase angle, the 120 was by multiplying the waveforms in the scope. Both the current and voltage waveforms
    are pretty non-sinusoidal.
    The takeaway here is the power factor for the unloaded coverter is really very very low. So even the though the
    amp clamp reader gives a number, that is not how fast the watthour meter is spinning, by a long shot. IF, and only IF
    it is a residential meter. Those ignore reactive power, at least the Con Ed ones here do.
  14. #14
    Virginia
    27,784
    7561
    8635
    Quote Originally Posted by jim rozen View Post
    LOL! "used to do...much the same".. Then the local Goodwill had a Herman Miller computer desk donated. NICE!.
    I waited for the price drop. It became the power lab bench. Mind - just for the worng and controls. Motors, Variacs, transformers, etc. are not ON it. Mostly they are on reinforced furniture dollys, wheeled to and away.
    But.. there are two layers of bare 3/4" plywood cut to fit atop the original Herman Miller laminated top. Boxes of screws and clamps are kept handy.
    Each setup since I implemented that rig, I just screw-down everything from transformers to terminal strips, to perf-boards, to brackets for potentiomers, switches, breadboards, pin-jacks, to ... scrap Lucite or Lexan covers, to... whatever suits.
    I ain't dealing with 5V Vcc any longer whilst messing with machine-tool power.
    Lethal stuff, right next to low-voltage controls, nearly all of it, rather.
    Besides.. all the meters and the 'scopes are my own, I DO have proper HV leads, so with any given experiment literally "screwed down" it also serves as "non-volatile memory" as I take breaks t do other stuff. Or not do - and don't come back to it for long periods.
    Too many holes, flip the plywood. Haven't reached the point of swapping to the second sheet of it yet.
    Plywood has gone dear, but it is still way to Hell and gone cheaper than funerals.
