I was recently given a South Bend Magnaturn for the price of rigging. It has a 15hp main motor driving the hydraulic pump. I believe that this makes it a 12**. Maybe a 1218?. The problem is that the lathe was setup for 440v in it's last home and I have 220v supply. The motor itself has low/high voltage inputs and the big transformer which I believe is the stepdown for the cpu, relays, etc. seems to have some flexibility as far as input voltage. With a machine more complex than a mill with one motor, is this generally how dual line voltage capability works, switching the motor windings and any step down transformers? I'm wondering if all the low voltage components are driven by this transformer or if there is more to it. I saw one auction listing of a Magnaturn 1200 series lathe that had the power listed as 220/440, but I suppose this could be a different model or configuration. Any opinions or past experience would be greatly appreciated. I'll try to take some decent pictures of the panel box for any electrically inclined folks out there. Thanks.
