Ditch buggy
- May 31, 2020
Hello first time poster
I have a Moore jig borer no.3 and only have signal phase power, so i think i need a rotary phase converter set up? i have several different (pony) moter options for the converter and i was hoping to only buy the rotary phase converter panel.
Where to buy a good reliable rotary phase converter panel i'm thinking 10hp. (yes bigger than i need but may add another machine later)
which pony moter to use i have a few choices = 10hp GE MODEL 5KS215AC205 1750 RPM
OR 10HP GE MODEL 5KS256AL305 1175 RPM
Some general info= shop power signal phase 220, 200 amp 40 breaker panel only using 3 breakers in it so far fairly new shop
new to me Moore jig borer is 220 or 440 3 phase 50 feet from the panel as crow fly's
wire size?
where to put everything? close to the machine, close to panel?
any other things i should consider adding, voltage monitor or?
basic wiring skills
wire size?
basic wiring skills
