Help, What is this? Phase generator?
Results 1 to 16 of 16
    Mar 2010
    So. Calif., USA
    376
    142
    31
    Default Help, What is this? Phase generator?
    I saw this the other day and the owner said it was used to run 3phase on single phase. I haven't seen anything like it before.
    Virginia
    27,258
    7561
    8499
    Quote Originally Posted by EarlF View Post
    Looks like a Reischle crossbreed with Bergman Electricitats-Werie.
    West German made, so several years after Wierd Adolph finally did the right thing for once and exited the game.
    Not sure if it is a Rotary Phase Converter or a dynamotor, though.
    On-edit:
    Milking machine? For COWS? Not in the Kalifornikya SSR!
    Kalifornios can't be fooled THAT easily!
    They know very well that milk comes from STORES, whilst COWS have reality Tee-Vee shows!!!
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,148
    1018
    604
    Looks like a vacuum pump?
    Virginia
    27,258
    7561
    8499
    Quote Originally Posted by dalmatiangirl61 View Post
    Photos aren't the best, but yah. Could was.
    Kinda unusual to see lube-oil specs on an RPC!!!
    Mar 2010
    So. Calif., USA
    376
    142
    31
    Default Additional Photos
    Oct 2005
    15,092
    Looks like $.25 a pound "electric motor scrap"....
  7. Likes JohnEvans liked this post
    Feb 2011
    1,148
    1018
    604
    Yep, thats a vacuum pump! "IF" its good, its worth more than scrap, to the right person, finding that person is the trick.
  9. #8
    Oct 2005
    15,092
    Need to show pix of the other end, the orange/brown looking thing.
    FWiW looks like a milking machine....for cows...
  10. #9
    Feb 2011
    1,148
    1018
    604
    I'll be first to admit I don't know cow sh*t about milking cows, but guessing vac pumps would be needed for that too. Where I see these types of pumps is CNC routers for wood, it provides suction to the table, same principle as air hockey, in reverse.
  11. #10
    Mar 2010
    So. Calif., USA
    376
    142
    31
    The orange brown looking thing is an electric motor with a shaft to the other thing. I don't really know which thing drives which. I don't think it is a vacuum pump as the only connections on the thing are electrical.
  12. #11
    Feb 2011
    1,148
    1018
    604
    The brown thing is the motor, it drives the grey/whitish thing which IS a vacuum pump, pretty sure its called a rotary vane type.
    Post #5, 3rd pic, that is the port/pipe for vacuum.
    Not sure if that is dry or oil lubricated type
    Rotary Vane Vacuum Pumps
    And it looks like Rietschle is now part of G-D
    The History of Elmo Rietschle - Compressors and Vacuum Pumps
  13. Likes Hopefuldave liked this post
  14. #12
    Oct 2004
    Iowa
    3,153
    66
    398
    It is a Werie-Rietschle vacuum pump, and yes, vacuum pumps are used in diary milking machines. Milking systems back in the early 20th century were frequently provided vacuum from a manifold tap and valve from a tractor engine. My Allis Chalmers B has such a valve... and while I don't use it to milk cows, I HAVE used it to start a siphon from a rather large boat fuel tank that needed to be emptied into a lower tank...
    High vacuum is used for a variety of industrial functions, and it's also used to reduce moisture in food, particuarly canning... and chemical production. Seein's how water boils at much lower temperature as pressure decreases, it's perfect for reducing moisture content. A fine example would be reduction of water content of tomato juice, in order to make sauces, but without overcooking the tomatoes. A vacuum pot, with low heat, results in very rapid evacuation of moisture, but leaving everything else behind. In machinery processes, high vacuum will remove moisture from machine oil in a big hurry. It's not unusual to see it paired with a centrifuge to separate moisture and heavy contaminants in a combined operation.
  15. Likes dalmatiangirl61 liked this post
  16. #13
    Oct 2005
    15,092
    Quote Originally Posted by DaveKamp View Post
    ...and the fact that this one appears to have been stored at the bottom of a large pile of manure...is junk.
    alum. parts corroded, steel parts rusted, the gut's inside are probably frozen as well.
  17. #14
    Sep 2006
    Sacramento County, California
    3,717
    2349
    1265
    It's possibly a rotary cheese converter. In any case, its story has been told. That train has left the station. The ship has left port. It's finished, terminado, finis, Ca-Ca, over and out.
  18. Likes digger doug liked this post
  19. #15
    Oct 2005
    15,092
    Quote Originally Posted by Newman109 View Post
    It could be a drive unit to enable the OP to reach "plaid"....as in "Ludicrous speed"....
    YouTube
  20. #16
    Oct 2004
    Iowa
    3,153
    66
    398
    Sir, the radar has been Jammed! (I think it's STRAWBERRY)
    Scotty, what's all this 'beaming' stuff?
  21. Likes digger doug liked this post
