Hello, I purchased a used rotary phase converter but I am not sure which set of wires is T and which ones are L. The wiring diagram is attached. It's a little fuzzy when the wires go into the cabinet on the motor where the capacitors are (ie what happens from the caps to the idler motor). For example, I am not sure what the blue wire is connected to at the caps and motor. However, I haven't disconnected anything. Looking at the diagram you will see "NOTE 1". On that side of the fused switch there were two wires connected to the black and blue wires but only one connected to the red wire. One each of the black and blue wires went down into the idler motor and capacitors. The other one each of the black and blue wires were louse and had electrical tape over their ends (applied by whoever removed it from service). At NOTE 2 in the diagram there are two each wires coming from each terminal on the fused switch (two black, two blue, and two red). None of those wires go anywhere. SO WHAT I DID: I applied 110V to NOTE 1 black and 110V to NOTE 1 blue. I did nothing with the neutral from my source (my breaker box). As soon as I turn the breakers on at my source the idler motor starts spinning. If I check voltage at NOTE 2 Black and Blue I get 220V, same with Blue and Red, and Black and Red. BUT, the manual switch (ie Fused Switch (3 Pole)) in my diagram does not shut off idler motor (which makes sense based on the wiring diagram). The only way to shut off the idler motor is to trip the breaker at my source. This seems unusual, though I can always insert another switch ahead of the Fused Switch. But, it makes me wonder if I am wiring it wrong (to T instead of L??). Of course the Fused Switch does shut off power to the NOTE 2 Black, Red, and Blue wires. SO... is this correctly wired, and the NOTE 2 Black, Red, and Blue wires are my 3-Phase power? Hopefully my questions make sense. If not let me know and I will try to explain better. I am new to this so thank you for any assistance.
