I posted some pretty specific questions on wiring the E-stop and controls on a UK spec 4KW single phase Omron/Yaskawa V1000 (same unit) for use on a woodworking chip collection system fan a while ago and got no response - perhaps because it's an EU unit there's not many familiar with.
Getting it wired seems to keep on throwing up more complications - initially it seemed to be just a hook up the power in/power out black box job. Maybe some more general input based on normal safe and (small shop) practical VFD wiring practices is possible??
There's three functions causing me some bother, in that there's fancy fault and safety relays mentioned in the manual which (a) are complicated for a mechanical guy, (b) expensive at about $150 each and (c) a cause of worry in that the installation needs to be safe and reliable.
The safety relay it seems is used when wiring E-stops to trigger the safe disable function. It seems like the relay delivers functions that are not needed in my situation, and that I can probably wire a simpler single n/c locking E-stop button to trigger the function (which stops, but does not power down the drive), and use the touch pad on the VFD to reset. (the fan is fully enclosed, and not a safety risk - it's more about protecting the motor and drive in the event of clogging caused by a bin overflow)
A fault relay (faults are a particular more serious category of alarm or error) seems to handle tasks like dropping out a n/o contactor in the incoming power supply (is one needed? - the plan was just to use a normal type C MCB to protect the drive/shut down the supply) in response to an internally generated digital fault output signal from the unit, or the switching of an external (?) thermal relay.
The thermal relay referred to seems to be the temperature sensor in the motor - I would like to hook this up for safety reasons, but think it can probably be wired simply by connecting it across the two listed terminals on the drive
The plan is to control forward run/stop fairly simply with just a rocker switch in the connection from a common output terminal to the relevant digital input terminal.
Speed (to raise motor rpm from 2850 to 3450 rpm - to compensate for our 50Hz power) and soft start setting (to control start up amps) are once-of commissioning tasks which can presumably be handled from the touch pad on the drive. Once these are set then forward run/stop is the only control input required, this seems to be just a matter of closing/opening a n/o switch (the rocker above). When not running the drive would if wired as described remain powered up, but it would be powered down when the shop is unoccupied (along with the circuits powering all of the other machines) when power is cut using the shop isolation switch.
Can anybody help by listing what control functions and protections are normally required in a basic VFD installation like this for it to be regarded as functional and safe?
How are the functions I've listed typically wired/controlled on a VFD in a simple workshop motor on/off installation? I'm hoping the fancy relays are overkill/manufacturers on the make/only required in more complex industrial environments vs. this one.
ian
PS On the say so of the supplier I've used 6mm2 shielded cabling for both the single phase input, and 220V 3 phase output. Yaskawa suggest 3.5 - 8mm2, but both runs at 3m each are very short (the manual talks of runs of up to 100m) in my installation and the voltage drop at full load calculates using their formula as a tiny fraction of the permitted 2%.
ian
