Empireweld
- Feb 19, 2007
- Cucamonga, Ca. USA
I have a mitsubishi spindle motor seevfv that has specs of 130v 1500rpm/ 170v 4500rpm/ 170v 6000rpm. The motor is a 4 pole, so I assume it spins at 1800 at 60hz. The drive I have is Frenic 5000p11 and is limited to 120hz. So if this is correct I would be limited to 3600 rpm.
If I was to use this drive would I set the max voltage to 170v?
