How do older Phase Perfects usually die?
Results 1 to 10 of 10
    Jan 2003
    Canada
    11,568
    6347
    3722
    Default How do older Phase Perfects usually die?
    For those of you who has PP's die, did it just not turn on one day, or just let the smoke out or something while running?
    I've got a 10hp blue unit, bought in 2007 I think and it has run pretty much 7 days a week since. Changed filter caps about 2.5 years ago I think, and originals sill read good on meter.
    I noticed in the last few months that when a machine is running(mostly the 7.5hp lathe), the high pitch from the PP gets quite a bit louder, which isn't something I ever noticed before. Is it a sign the IGBT's are getting old and tired? I'm sure I have over 30k if not 40k hours on it. Still runs every day but I feel like maybe someday I'll flip the switch and nothing will happen?
    I've been thinking of buying a new 10hp unit of the newest generation, but kinda also wonder how much longer this old one might go on?
    Jan 2003
    Canada
    11,568
    6347
    3722
    I guess nobody here had one quit, or everyone's too deaf to hear the high pitch change?
    Anyhow, read a bit on IGBT's failure modes and I suppose this thing probably is starting to get tired by now so I'll order a new unit soon, I'm kinda curious to see the newest generation of these. How much longer this one has might remain a mystery, but it has served me very well many years.
    Jun 2001
    St Louis
    19,056
    2279
    3527
    Electronic semiconductor devices in general have what is termed a "bathtub" failure curve.
    Initially, there is a high failure rate, as the "good" but borderline devices get weeded out by random stresses.
    Then for a long time, there is a low failure rate.
    Eventually, especially with semiconductors, "wearout" mechanisms start to come into play, and things start to fail at a higher rate. Except in the most stressed devices, you can easily get between 10 and 15 years operation.
    Some of the failures are:
    migration of the "metallization" the forms the conductors on the chip surface, to where clearances are reduced below minimum,
    cumulative effects of heat stresses gradually cracking the "solder" that holds the chip to the heat dissipating block in power devices, so that the chip overheats.
    In non power devices, the difference in thermal expansion between the plastic encapsulation and the chip may eventually crack the tiny wires that connect the chip to the solder pads, because those wires may be encapsulated by the epoxy case material.
    In power devices, plain thermal expansion and contraction may eventually fatigue the wires, or even solder joints.
    If the parts become overheated, or even if not overheated, eventually the "doping" of the chip, the materials that are heat-diffused in to form the "works" of the chip, may diffuse further, and ruin the internal structure.
    Many recent products. and PP are among them, rely on programs stored within the control unit in some form of "ROM" (read only memory). The newer types are not actual physically changed to write the program into them, they rely on stored charges which will eventually decay and "forget". (Old ROMs used "fuses" that were actually blown open, and are probably somewhat better as far as decay of the program storage)
    Manufacturers work hard to make those failure mechanisms less of a problem, but 25 year old solid state electronics are getting toward the "suspect" stage in most cases. There are exceptions.
  4. Likes SND liked this post
    Jul 2004
    Houston, TX USA
    31,943
    Mine bought new 2005 still acts like it did the first day I powered it up - with never any issues
    Aug 2014
    bainbridge island
    1,357
    288
    335
    I would investigate the snubbers on the IGBTs.
    Depending on the topology, there will be a resistor, diode, capacitor, but its unlikely they used an inductor or even a transformer to put the energy back into the supply. so anyhow any of those components can fail.
    In addition to the snubber circuitry there should be a film capacitor bolted directly on the igbt across the dc bus. that film capacitor can fail as well.
    I don't know what they use for dc electrolytic capacitors, but they can fail as well.
    Aug 2012
    California, Central Coast
    5,100
    2374
    2102
    wheelieking had one fail. If I remember it right it fried a lot of electronics and almost burned down his house (on the same circuit as the shop), a search should find the old thread.
    Oct 2010
    Oregon
    5,630
    5423
    2122
    Quote Originally Posted by SND View Post
    10 years ago the high-pitched whine (at idle) used to drive me crazy. When actually running the lathe, I can't hear it because the lathe drowns out the whine from the PP.
    Today I have so much hearing loss (and have piled so much stuff around the PP box) that I no longer hear the whine.
  9. #8
    Aug 2014
    Wisconsin Rapids WI
    427
    85
    I had a used blue one blow soon after I bought it. The board was no longer supported so I was SOL. The seller had issues ( failed to disclose that ) and sent it to PP who checked it out. The seller ran for cover but PP gave me a very good deal on a new one. I have two other blue ones that are still working. If it is critical I'd buy a new one and keep the old as a back up. I have one that I plug into a 50 amp receptacle when I need additional capacity. Dave
  10. #9
    Aug 2004
    Ohio, USA
    2,132
    311
    119
    20HP PP blue box (1st gen). Purchased from original owner, he was upgrading to a bigger unit to run a new machine. It worked great for me for about a year. Shut it off one evening, went to start it back up the next day, DOA. Powers up for a few seconds (makes 3 phase) then it shuts off. PP does not support the blue boxes anymore. I have a friend that is excellent with electronics repair look at it-he also consulted with a friend that designs electronic units that share similarities to the PP. Long story made short, its an uphill battle to fix it, so I purchased one of the 3rd gen units new from PP.
  11. Likes SND liked this post
  12. #10
    Virginia
    18,921
    7561
    11646
    Quote Originally Posted by JST View Post
    Concur. Very well summarized thanks.
    Ditto.
    NASA built as many as they could into such kit as "Voyager" DEEP space craft.
    Sure did pay-off. But "cheap" it had not been. Glad they at least published, though!
    Minor curio was that "at one time" a return to vacuum tubes was proposed for spacecraft. Open air ones, even.
    Because one didn't have to WORRY about a tube failing over going "gassy" ...when "open air" was a damned hard vacuum .... at no extra charge.. and for a VERY long time!
    No doubt some Government chair-warmer shot THAT idea down off the possible contamination off launching through a cloud of lunar green cheese flakes and mold?
    Cautious, some folks can be when a gummint retirement plan is at-risk!
