Spud
- Jan 12, 2006
- Brookfield, Wisconsin
Industrial saturated steam cleaner (vapor steam I believe). Made in Italy
3 phase
480 volts
60 Hz
22 amps
18 kilowats
Not the same as below model but similar. Below Model is Euro spec version so it is 400v and 50 Hz
http://www.reasteamcleaning.com/docpublic/doc_eng/depliant-2015-S18E-v1.pdf
All I have is one 220 Volt single phase outlet that is used to power the washer or dryer.
So what kind of equipment do I need to be able to run this steam cleaner?
A VFD or do I need a rotary or digital phase converter?
Suppose I was to use a gas or diesel GenSet to provide the electrical requirements, what spec GenSet would I need ?
3 phase
480 volts
60 Hz
22 amps
18 kilowats
