DocsMachine
Titanium
- Jan 8, 2005
- Southcentral, AK
I'm working on installing a Trak 2op CNC mill, sort of a miniature VMC, into the shop. From what I've read, it has no option for single-phase power, so I have to feed it 3Ph.
Not having native 3-phase, I have a new American Rotary converter, supposedly "CNC rated". The chart that came with it basically showed the generated leg within a few percent of the native legs. I have not put a meter on them myself to see.
I believe I've wired the machine so that the computer gets the two native legs, and will double-check that before I light the thing up. (Still going through the manual checking off the service points- it's a well-used machine, and I've already found a few easter eggs. )
Short of springing for a Phase Perfect or something, what else can I do?
Along with that, I've read posts about how voltage-sensitive some machines are; if it says it needs 208 volts, you better feed it 208, and not 220v or 240v. Nothing in my documentation- that I've found, yet, suggests such a sensitivity. Anyone have a Southwest Industries machine and have experience with what it might or might not be tolerant of?
Basically, I obviously don't want to damage this thing by some bonehead move. No tech is going to come to Alaska to fix it, it's long out of warranty, and I don't want to have to buy a new $2,500 speed control or something just because I didn't ask a stupid question. \
Doc.
Doc.
