flagvan2000
- Feb 26, 2020
I installed a Hydraulic Press Brake. It is running a 10HP 220 volt motor. I updated to a 40 HP Rotary Phase converter. Using a north american soft starter Rotary phase converter Panel with a used WEG 230 volt 40 HP idler Motor.
The problem i'm having is When the Press has a load the incoming Volt Drop from 245 to 195-200 volts when loaded. Which kills the hydraulic power and can't bend.
I have also attached Picture of the idler motor i'm using for the rotary converter and a link for the soft start Panel
Rotary Phase Converter Control Panel CP-40
Does anyone have a idea what could cause this or what i could do to fix?
