I知 having a brain fart. Is this transformer delta/delta?
Results 1 to 9 of 9
    Dec 2018
    West Virginia
    7
    Default I知 having a brain fart. Is this transformer delta/delta?
    The new acme model number for this transformer is delta/delta but this one doesn稚 specifically say. I keep having a brain fart but the windings look weird to me.
    May 2020
    Minnesota
    541
    216
    226
    Image is microscopic
    Dec 2018
    West Virginia
    7
    Quote Originally Posted by Just a Sparky View Post
    This better?
    Jun 2001
    St Louis
    19,568
    2486
    3757
    It is effectively delta-delta, yes.
    The actual internal wiring is like a high leg 3 phase, but the center tap is not brought out. So the only connection options are as delta-delta.
    There is no option for a ground on the secondary, other than a corner ground.
    Dec 2018
    West Virginia
    7
    Quote Originally Posted by JST View Post
    Great thanks. So I can just come off H1, H2, H3 straight into my 480V delta motor, correct?
    Virginia
    21,073
    7561
    12314
    Quote Originally Posted by WVHick View Post
    The new acme model number for this transformer is delta/delta but this one doesn’t specifically say. I keep having a brain fart but the windings look weird to me.
    They only "look weird" because (s)he who drew it optimized use of "presentation space" to get readability onto a smaller label!
    Re-draw it yerself - on nested triangles rather than stacked rectangles - initially leaving off the taps ... and see it as the classical Delta-Delta.
    Then add the taps... and it should make perfect sense.
  7. Likes WVHick liked this post
    May 2020
    Minnesota
    541
    216
    226
    Agreed, that's a dumb drawing. Some engineer felt the need to justify their existence by taking something well-established and making it needlessly complicated.
    So complicated in fact that I nearly didn't notice that what you have appears to be a "Scott - T" transformer, not a delta-delta. Used for converting two phase to three phase and vise-versa - though yours appears to lack the connections needed for that. I believe the technical term for what you have is an 'odd duck'.
    Notice the vector diagram in the bottom right.
    Interesting find.
    As far as secondary grounding, you're looking at either a corner ground or a separate 'zig-zag' transformer (unlikely as those are usually for impedance-grounded systems).
  9. #8
    Jul 2007
    Missoula Mt
    1,444
    62
    710
    Its not delta, special y , or scott conn like sparky said...It will work for you...Phil
  10. #9
    Mar 2009
    6,433
    126
    1249
    You're mighty lucky it isn't Delta/Variant ...
  11. Likes Yan Wo liked this post
