Suprised - guessing you would advocate tying a bag of acorns to the shaft. When the main motor runs, the squirel sees the acorns and steps on a treadle switch to try to catch them. And turns on the second motor.
Team squirrel up and quit. Whole krew last seen under the usual blue fog of an over-age-in-grade screeming-meemie GMC off a salvaged 1949 Greyhound bus.
Diaries and cellphone records indicate the wuz heading to Peekskill, NY to hire-out for kinkey-fuckery "Keyhole" entry brain surgery.
ou really don't want to known what a kinky squirrel might consider a "keyhole", but the anecdotal evidence sez their last Collitch Prof was a retired Hamster of a proctological persuasion..
Didn't have the heart to tell 'em their intended benefactor wuz at-risk of leaving them with medical bills unpaid off the back of croaking on an anally-retentive "TDS" spew after the motorsickle accident saw them sew his arsehole shut off mistaking it for a brain aneurism.
What ever happened to those SSRs? Forgot about those?
WTF have you NOT "forgot about?"
The ones I use "the most" trigger off as low as 3 VDC to 35 VDC - which fires an LED mated to a phototransistor, so "obviously" already have a bit of network organic, LED's needing such.
Cheap Hall effect, packaged, else Old Skewl vacuum mag-reed could do, here, too.
I'm grown too stupid for this s**t in me dotage, so just put the juice pumps on an ignorant toggle switch of their own.
Not interested in having my ones flooding and squirting when a spindle is turning.
Only when a tool is in the cut AND it is an op, alloy, and tool
au fait with coolant, given not all of mine ARE.
That said, ISTR our Brother, the OP, has got that interdependencies part already sorted by means of integrating other gating then vetting via a DeMorgan Truth Table?
