Metalurgent
Cast Iron
- Feb 14, 2013
- New York City,
I'm retrofitting a Tree Journeyman that's been out of action for a few years. I reset the Yaskawa CIMR vfd to factory presets and got the spindle motor running at the default settings.
The motor made some noises that I assumed were bearing problems so I pulled the motor and have new bearings on the way.
I came across a warning that a drive needs to be reconditioned if it has sat unused for a while ( quotes below..). I'm new to this stuff so that recommendation seems odd to me. It this a generally accepted practice??
"VFD can sit unused and without power for a short time without service. If a VFD has been stored for longer durations, the dc bus capacitors must be reconditioned. The electrolyte inside the bus capacitors changes state when unused for long periods. Reconditioning requires running the drive with no motor leads connected for at least 8 hours before trying to run the drive under load. Repowering the drive under no load brings the electrolytic charge back to a proper charged state."
