Isolation Transformer Wiring Help Needed
Likes Likes:  0
Results 1 to 4 of 4
    Aug 2004
    Ohio, USA
    2,120
    311
    110
    Default Isolation Transformer Wiring Help Needed
    I have a GE QL series drive isolation transformer I'm looking to use with a phase perfect. I'm a little confused in regards to wiring it up...I believe H1, H2, H3 are for my Delta power input. Are X0, X1, X2, and X3 my Wye outputs, or is it Y0, Y1, Y2 and Y3? Why does it appear that there are 2 Wye output taps?
    Jul 2014
    MI USA
    884
    197
    367
    Default GE Drive Isolation Multitap Xformer
    Your Model was a special made around 2005. It does have two Wye output windings as indicated on the tag.
    X's are 460/266V @ 20KVA capacity, Y's are 230/133V @ 7.5KVA
    A similar but not exact connection diagram, Yours has the two Wye output windings.
    SAF Ω
    Jul 2008
    Philadelphia
    1,942
    514
    445
    FWIW be aware that XO shown on the star or wye config may not be accessible on the xformer, like on a 3 phase dual voltage AC induction motor.
    The fact that you are lucky enough to have a schematic of sorts and numbered wires. I would still ohm the thing out, just to be sure all is okay and the smoke that makes all electrical devices work won't be let out.
    Jun 2006
    San Jose, CA
    580
    495
    55
    Quote Originally Posted by Machinery_E View Post
    Can you take some clearer/better pictures of the terminal bars?
    It’s really hard to read them.
