dstankus14
- Oct 2, 2017
I have a GH 1340A lathe (321350 PN). This lathe takes in 3 phase and uses it to power several different things. It has a power light, a transformer that takes the three phase 200v and steps it down to 110, it has a coolant pump motor (three phase 1/4 hp or so) and a main motor - the main motor can run at 2hp or 3.2hp at double the speed. Since I also have a 3hp 3 phase mill, I purchased a FRN0012C2S-7U AC Drive, 3hp, 230V, Single Phase, Compact Micro Drive. This VFD is more than capable of driving the lath motor at 3 HP setting per the specifications. The issue I am seeing is that when I have the motor switched to 3HP and try to turn it on - the magnetic contactor intermittently turns on and then off and then on and then off in an intermittent fashion. Eventually the motor will start but I know the sudden on and off action is not good for the drive. In the 2hp setting the lathe works fine. If I set the lathe in 3HP mode and manually activate the contactor the motor also starts fine. I spoke to a technical resource from the place I bought the drive and he told me to directly wire the high side of the motor to the VFD. This would be an easy solution but then I would not have the use of the coolant pump or the different motor speeds. Does anyone have a suggestion as to how to get around the magnetic contactor issue without bypassing all the electronics? I have included a wiring diagram of the lathe as well for reference. Again per the specifications the VFD should work fine with the lathe motor in 3HP mode and I proved it by manually actuacting the contactor and had the motor start fine.
