Just picked up a 1440 ,3 phase Motor 7.5HP was wired to 440v , changed it to 220v , my house is single phase only.
my question is with the reduced voltage what size Phase-A-matic converter do I need ,seem to remember you reduce the volts the HP of the motor goes down. This Lathe will be used for light use in my garage,
I have a 1200PMD converter on it . Turned on once and then nothing ?
Any suggestions.
Thanks Peter
Any suggestions.
Thanks Peter
