Fully Defined
- Oct 12, 2013
- San Francisco, CA
Is there a way to reset faults on KB Electronics VFDs? I tried setting parameter 0610 to 0000 (factory setting), to 1010 (default program) and to 1111 (60Hz) - which are probably identical - and none of them removed the SC fault. Is it possible to reset faults on this drive?
Long story but I had to solder in new 1500 uF capacitors on the power board after wiring the power incorrectly on a KBDF-27D VFD. That brought it back to life, but it gives a motor short circuit fault despite never having had a motor attached (the motor is fine, BTW).
