Large shop wiring
Results 1 to 18 of 18
    Aug 2004
    Michigan
    108
    Default Large shop wiring
    Recently i have been thinking about wiring up my shop for 3 phase loadcenter instead of running cords all over the place one at a time.
    I have a 40x64 shop, and 3 phase machines are concentrated in opposite corners, metal and wood don't mix too well, so does it make sense to run the rpc by the main 200A load center and feed a 3ph panel right there for the loads in that corner, and run a subpanel in the other corner of the shop for the wood machines? I have welders and machine tools in one corner and 3ph wood machines in the opposite corner. i think it might be expensive to run circuits from one corner to another?
    What's the building size point where subpanels start to make sense?
    May 2010
    northern Indiana
    93
    10
    I will soon have about a hundred feet of small bus bar and plugs for sale if you would be interested,
    [email protected]
    Aug 2004
    Michigan
    108
    Buss bar and plugs sounds expensive.. LOL.
    Oct 2010
    Oregon
    4,920
    3973
    1773
    I have a substantially smaller (24x27) shop, with one wall being 50% overhead door. I put the phase converter and a 3-phase loadcenter in the corner by the utility supply panel, ran 4x4 raceway around the three non-door walls of the shop at 12 feet above ground (because there wasn't room on the ceiling above the raised door and snaking around all the ceiling mounted lights), and ran conduit drops from the raceway down to outlets and safety disconnects at various places around the shop. There's still lots of room in the raceway for more circuits, but no room on the floor for more machines.
    Aug 2004
    Michigan
    108
    Can raceway sit on the ceiling? Would work better for my shop. I have airlines and such on the wall in the way
    Oct 2010
    Oregon
    4,920
    3973
    1773
    You can certainly get something that suspends from the ceiling, but your local authority having jurisdiction (the electric code people, local to you) might want to see UL certification for the purpose.
    My support brackets stand the raceway off the wall about an inch, IIRC. SquareD also has drop hangers to mount on the ceiling, or bracket hangers to mount on the wall with more clearance between the wireway and the wall, and I'm pretty sure all the other raceway makers have the same.
    You could run one conduit with heavy wire across the ceiling to a small subpanel on the opposite wall, then take your branch circuits on that side from the subpanel.
    Aug 2004
    Michigan
    108
    Small 3ph subpanels seem rare.
    Sent from my LG-TP450 using Tapatalk
    Oct 2010
    Oregon
    4,920
    3973
    1773
    I think, without going to the shop to look, that my Siemens 3-phase panel (purchased off the shelf at a local Home Depot!) has 30 spaces. So limited to 10 three-phase circuits. Not what I would call tiny, but not a huge industrial loadcenter.
    Aug 2004
    Michigan
    108
    I have a couple of ras, a jointer,, a planer, bandsaw, and table saw in the woodshop. So 6 circuits would work. In the other half, a Bridgeport, lathe and hoist. Half a dozen each corner would work. I already have one panel with enough spaces.
    Aug 2004
    Michigan
    108
    Maybe it makes sense to put the main panel in the woodshop as I have more circuits there.
  11. #11
    May 2006
    Illinois
    227
    83
    38
    I recently finished an addition to my shop and found a used load center from: Load Centers - Used, For Sale, Buy, Sell, Trade, Used Equipment Supplier, Dealers
    Was very reasonably priced and a lot cheaper than new.
    gm
  12. #12
    May 2006
    Illinois
    227
    83
    38
    gm
  13. #13
    Aug 2004
    Michigan
    108
    I didn't see anything i can use there. They did have bussway and plugs, but i think that's going to be more expensive than conduit and wire for this project anyway. I did find a couple 3ph panels locally on craigslist.
  14. #14
    Aug 2012
    California, Central Coast
    2,858
    2095
    1057
    Unless you are close to retiring and closing the shop go with the small raceway, so easy (read cheap) to add more circuits in the future.
    What does indianamoon have?
  15. #15
    Sep 2002
    People's Republic
    2,605
    190
    1912
    Bus duct
    Find a good deal on a whole setup as the pieces get pricey if bought one at a time
    I found a deal on ebay when I moved into this shop and got 100+feet plus boxes for 100 bucks
    Guy was happy for the money, he got paid to tear it out and paid by me, and I left him the aluminum raceway[ladder looking stuff for above suspended ceiling] and he sold it for scrap
    Long term it is cheap as you can move and change and take it with you
  16. Likes motion guru liked this post
  17. #16
    Aug 2012
    Pittsburg, KS
    1,215
    108
    546
    My shop is 50x120 with the power coming in on one end. Lots of my machines are at the other so I ran a subpanel up there because I wasn't going to pull wire 100+ ft for every circuit. Another consideration as to deciding is to weigh in on how much stuff is in the space that needs wired, if you have long runs but it is all open and easy, then pulling everything from one side is not bad and really comes down to wire/conduit cost, but if you have lots of stuff in the way of doing the work, then you only want to do it once.
    I have not used raceway, I don't think anyway, so not sure how it is different than a buss bar. If I had to start over from scratch I'd seriously consider a buss bar as long as I could find it cheap. Had it at the old job and it is very nice for when things need to get moved around. I have heard that HGR has some sometimes. My shop had 3 phase when I bought it and had SqD panels and I picked up a couple used ones to add in where I wanted it. SqD 100 amp breakers aren't cheap. But big fuses aren't really either.
    I think putting your main panel with the most available spaces where the most machines are and then put a sub on the other side would be the simplest.
    I got a lot at a sale of disconnects so I have a 100 and 200 amp fused disconnect that I am probably not going to use. Both SqD, let me know if you are interested, be cheap.
    Jason
  18. #17
    Aug 2004
    Michigan
    108
    Looked on eBay and nothing even close to affordable. Hundreds per section was the norm
  19. #18
    Sep 2002
    People's Republic
    2,605
    190
    1912
    Quote Originally Posted by 86turbodsl View Post
    ebay has gotten stupid
    try to find an actual auction or perhaps craigslist or facebook
