Cole2534
- Sep 10, 2010
- Oklahoma City, OK
In my other thread (https://www.practicalmachinist.com/...-square-wave-355-amp-draw-399703/#post3888693) I learned about how these work and why they're installed.
In the end, it'd be favorable for me (I think?) if I could switch between engaging or disengaging them based on need.
My question is this- short of empirical analysis, how can I tell what voltage these capacitors use to operate and how much amperage can they discharge?
Thought is that if they're less than 600v and 10a I could use a normal 30mm switch and contact blocks to make this work.
I am clearly not an electrical wizard, if I'm way off my rocker that too is an acceptable reply.
Here's a pic of the cap in question. It's connected with 12ga wire via 3/8" spade terminals.
