Strostkovy
Titanium
- Oct 29, 2017
I need an air compressor for my apartment and don't want it to be cycling on and off at full power being extremely noisy when I only have a little bit or periodic air use, especially at night.
I figured it would be a fun project to make a servo air compressor, that cranks the compressor just as fast as it needs to.
Long story short, the treadmill motor I expected to work is even junkier than I thought, but I can get a decent deal on a 3hp 1175 RPM motor and single phase to 3 phase Hitachi VFD with sensorless vector control and analog inputs.
I have already designed the PD servo loop and it has minimum speed cut out and cut in, and a maximum ramp up speed so it should be VFD friendly. The control system also operates a fan for the ODP motor, VFD, and TEC air dryer, along with controlling the TEC power to stay at the right temperature.
That's the plan anyway.
The compressor is stated to draw 2HP at 9.9 CFM and 150 psi and 1050 RPM, but I think it will take more than that. Pulley ratio is 4:3 motor to compressor, so I will stay a bit below the compressor's max speed and will probably keep the servo loop set at 100psi or less. The compressor bypasses as much as it pumps at around 30 rpm for 40 psi and likely 60 rpm at 90psi, so there is no point in running that low.
Bottom line is: Is it practical to run a 1200 RPM motor at ~80 RPM and still reliably get at least 70% rated torque out of it continuously? I think I've covered all of my bases but want to run it by other people.
9.9 CFM Twin Cylinder Air Compressor | Belt Driven Compressors | Air Compressors & Vacuum Pumps | Air & Pneumatics | www.surpluscenter.com
3 HP 1175 2 /4 VAC 3PH GENERAL ELECTRIC MOTOR 184T | GENERAL ELECTRIC | Brands | www.surpluscenter.com
3 HP Hitachi Variable Frequency Motor Drive WJ2 - 22SF-CP | Variable Frequency Drives | 3 Phase AC Motors | Electric Motors | www.surpluscenter.com
This is more expensive than my DC treadmill motor attempt, but paying for a VFD is plenty worth it to avoid having to build a fairly high current IR compensated drive and worry about smoking out undersized motors.
