Hi all,
I've got a lathe with a single phase, dual capacitor, 1HP motor.
For years I've been meaning to upgrade it to a 3 phase motor with a VFD, so that I can have easy speed control on the lathe. Now is the time.
I have two VFDs, one cheapo chinese one which I have successfully used in the past to run my 3ph bridgeport motor off single phase power, and another Danfoss drive that I acquired through work. I do have 3 phase power available (one outlet only) but it is being used by another machine so I think it will be more convenient to run the VFD off a single phase outlet which is right near the lathe.
I did acquire a suitable 3phase motor, with the intent that I'd install it, but it has a different shaft diameter, and I'm now thinking there's a much simpler way, by using the existing motor.
So, my question is, can I modify the existing 1ph motor to run on 3ph power?
Below are photos of the motor nameplate and internals. To me, the windings look identical to that of a 3phase motor (3 pairs of wires: red/yellow/black), so I'm thinking that I should just be able to pull the capacitors out and wire it up like any 3phase motor. Is that correct?
Hugh.
Hugh.
