I have a 2.75 hp 3 phase specialized machine which was manufactured in germany. The specifications call for a 208 volt delta power configuration, 3 hot wires and a ground.
I want to run it using a phase-a-matic R5 phase converter with the CNC box, which I added because the voltage on my single phase panel runs high, about 242.
The machine has minimal electronics, the contactors and an electronic timer (all 220, since there is no neutral).
My single phase panel has the neutral bonded to ground. Is this acceptable for this device or would I be better to run an isolated ground (i.e. a seperate wire to a rod in the ground)?
What is the difference between a "3 phase disconnect" and a 3 pole single phase disconnect? I find boxes like this:
http://www.amazon.com/SIEMENS-GF321NR-240-Volt-Outdoor-General/dp/B005G95JX8/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I3TQGFBH1ZE100&colid=563L69A6KZVD listed on one web site as being a 3 phase disconnect and on another site, the same device being listed as a 1 phase 3 pole disconnect. Are they interchangable, or might the single phase 3 pole device have a neutral bond to one of the poles or something? I would guess that would not matter since I will not connect a neutral to the box.
Thank You,
Nataraj
Thank You,
Nataraj
