Hi, I have a 3 phase 380V 2.2kw vfd
and a 400v 50hz 2 pole, ac motor
the vfd turns it ok, in both directions.
the vfd speed is set by 0-10v input.
if the voltage drops to 0.7v, 0.6v
the motor stops turning, or turn very little every few seconds, and not continuously.
is it because its 2 pole ?
What's been said, but yes, you want an 8-pole AC motor to even get close to that low an RPM, still with the limitations, plus some OTHER trade-offs you may not like.
IF/AS/WHEN you NEED really low RPM that can tolerate even sitting at-rest and still "pull", you need a servo with its specialized drive system, or at least an AC "torque motor" (think lift door closers), or a DC motor. Also serious external fans, most cases.
Search "blower duty", find lots of old DC motors that had to "sit still" so as to act as infinite springs, holding tension, then speed-up to move something in a manufacturing process of some sort. Making fabrics, rubber belting, sheet steel coil - lots of "stuff" needs that.
Otherwise, yes, the "generality" is that AC + VFD prevails for base RPM UPWARDS, DC prevails for base RPM DOWNWARDS, they have a useful overlap where there isn't much difference except that DC motors usually cost more than AC.
Servos just do WTF they are told to do. It's why we CALL them "serve o's"
