Machinery_E
Titanium
- Aug 19, 2004
- Ohio, USA
Motor-Dual voltage 230/460 3HP Dayton "Watt-trimmer" 3 phase motor.
Drive-Hitachi WJ-200 2KW VFD.
Previously was running a Baldor 1HP motor with the drive. Ran great. Needed more power, so tried putting the used Dayton motor on the machine. Changed the parameters on the drive in regards to the amps of the motor. In sensorless vector mode, the Dayton motor is very jerky in trying to start. The spindle on the machine turns easily. Take the belt off, and the motor seems to have a slight hesitation, but it starts and runs without a problem. Put the drive in constant torque mode, the drive starts the motor connected to the spindle without a problem, but the Dayton motor sure doesn't seem to have any power-its worse than the 1HP Baldor.
I put another motor I had on the machine-a 1.5 HP motor. Runs great in sensorless vector mode and has good power.
Is there such a thing as a motor that is not compatible with a VFD? Or is my motor bad? It came in a lot of stuff I got, and I'm not sure about the history behind it.
Thanks!
Thanks!
