Need 400V 3phase for CNC machine, best approach?
Likes Likes:  0
Results 1 to 1 of 1
    Oct 2019
    Florida
    Default Need 400V 3phase for CNC machine, best approach?
    Just got a DMG Mori machine delivered and it calls for supply power of 400V x3, N, PE (protected earth) 50/60Hz.
    ​​​​​​​My shop has 208/120 3phase power and I was planning to buy a local 480V to 208V delta Wye transformer and simply backfeed it as well as adjusting the taps to get below 440V.
    Wiring diagrams for the machine say this:
    "Isolating transformer necessary if:
    --- voltage <360V
    --- voltage >440V
    --- TT main
    --- IT main "
    With losses from backfeeding the transformer, I should be close to 400V on tap7 according to the diagram: https://i.ebayimg.com/images/g/HGMAA...nC/s-l1600.jpg
    But with the machine requiring a Neutral, is it possible to wire the high voltage side of the transformer in WYE configuration also ?
    I read several threads on here before making this post, I just need advice on this specific application.
    Any help is much appreciated!
    -Sean
