love4god
- Oct 6, 2016
- barbourville
Converting the South Bend for ceramic tooling.....Looks like a jet pump motor, Might not be the best motor to use, my guess is it is 3450 rpm if so find something else...Phil
as i'm aging i'm losing the mental capacity to understand these kinds of schematics and motor diagrams.
basically you've got a thermal protector with 1 input and 2 outputs.
both outputs are used when the motor is connected for 120, but only one when connected for 240.
the start winding connects to one end of the winding, goes through a switch and a capacitor... and is connected to the midpoint of the winding for 240v connections, or it is connected to the end of both paralleled windings for 120v connections.. it is also connected through the thermal reset device.
i think you only need 5 wires exiting the stator to pull this off for a non reversible motor.
if you want to reverse the motor, find the start winding and cut the lacing on the coil and find where it joins the other coil, and bring the required 6th wire out of the motor.
alternatively you can reverse the motor if you leave it connected for 240 but you would lose the thermal safety in (this case, counter clockwise rotation). in the event the motor overheated in counterclockwise, it would slow down and stop and as soon as the clutch engaged the capacitor and start winding would be left with current flowing through them. which one blows up first i would give it a 50/50 coin toss.
this isn't completely unacceptable to me in terms of risk, for a lathe or similar machine. it would never be left "on"
Notice
