CountryBoy19
Stainless
- Aug 14, 2012
- Bedford, IN
Edit: fixed! See 5th reply
What I know: 1/2 hp capacitor start gear motor. Controlled by momentary push buttons (think winch/hoist with momentary buttons to spool out and spool in).
Tonight, when engaging in forward I heard a rapid cycling/clicking of the contactor. Releasing the button did not stop the cycling. I panicked and pushed the button to run it the other way which stopped the cycling. Motor would not re-engage in forward and I could not hear the contactor clicking, although I did hear a hum. Motor operates in reverse just fine. I replaced contactor for fwd direction and no change other than a more audible click of the contactor.
It seems the motor is a standard 4-wire reversible capacitor start motor. It may be dual voltage as there is a 5th (orange) wire that is capped. FWD direction white & brown are to line, black is to neutral, and yellow is to capacitor. REV direction has black & brown to line, white to neutral, yellow to capacitor.
I was hoping capacitor but I suspect not considering it works in reverse. Other thoughts? I hope not winding, it's a proprietary motor and the mfr of the system will only sell a complete motor assembly at a steep cost.
What should be ohmed to verify winding resistance?
