spoonycoot
- Nov 22, 2018
I bought a 1.5 hp 3 phase machine and I'm replacing the motor with a 2hp single phase 240v motor. The motor starter can support up to 5hp single phase. I will post pics of wire diagram and motor starter.
From what I can tell I should just be able to use L1 and L2 and T1 and T2 everything should be correct. I will also need to bypass the heaters. T was planning on using a jumper. I'm assuming this is ok. The new motor has thermal overload protection.
Thanks for the help guys.
