Need transformer Wiring diagram help
Results 1 to 6 of 6
    Oct 2003
    Pinnacle, NC USA
    1,138
    1547
    48
    Default Need transformer Wiring diagram help
    Guys,
    I bought this Italian press at auction (online) in Surrey, BC.
    There is no name plate information.
    The motor data is 380wye/220delta 50 Hertz.
    From my reading 60 Hertz is standard in Canada.
    In the control cabinet there's a small tformer.
    From the attached pictures can guys interpret how this is wired?
    I have had no luck in learning how the shop was wired in Canada. The owner is overseas on holiday.
    I'm not sure if this tformer is stepping down the 480 to run the press near the 380 nameplate voltage.
    Tom
    Sent from my SM-G960U1 using Tapatalk
    Jul 2004
    Houston, TX USA
    29,516
    100VA is tiny, so I would suppose its a control transformer - making juice for relays / mag starter coils
  3. Likes TFPace liked this post
    Oct 2003
    Pinnacle, NC USA
    1,138
    1547
    48
    Quote Originally Posted by johnoder View Post
    100VA is tiny, so I would suppose its a control transformer - making juice for relays / mag starters
    Thank you John
    Jul 2004
    Houston, TX USA
    29,516
    Many such coils have the voltage they need printed on them in plain sight - which will be what the transformer is putting out currently
    Jul 2014
    MI USA
    879
    197
    363
    The control transformer is wired for 480V input, and 120V output for the controls.
    The motor is likely wired for 380V input, but powered at 480V 3Φ 60Hz.
    Motor will run fine at 480V 60Hz, but run at 20% faster than rated speed for 50Hz.
    SAF Ω
  7. Likes TFPace liked this post
  8. #6
    Oct 2003
    Pinnacle, NC USA
    1,138
    1547
    48
    Quote Originally Posted by SAF View Post
    SAF Ω
    Hello SAF Ω
    This is what I was hoping to find out.
    Thank you guys for the help!!!
    Tom
