machapungo
- Jan 23, 2011
- North Carolina, USA
I have a 10 hp 3 ph motor and a band saw with a 1 hp 3 ph motor.
I assembled a 4 capacitor circuit in an attempt to construce a "balanced" static phase converter.
Two of the capacitors are 3200uf electrolytics that were connected in series - Cap + to + cap - fashion to protect them from the 220 volt AC.
The other two capacitors were 150uf each and 450volt NON elyctrolytics. All were new. The run capacitor values were taken from a chart containing different HP values provided by someone on this website or on the "allaboutcircuits" site. This was done prior to a computer crash and I lost the info and it's source. ANYway!!
I had the band saw wired into the circuit to pick up it's 3 ph input from the 10 hp windings. To begin the band saw power switch was OFF. I applied 1ph 220v power to the circuit and the 10hp motor. It started and was running fine for a minute or two. As soon as it started I disconnected the start capacitor and it contintued to run.
Then I turned the band saw on and It started up fine, ran for about 5 to 7 seconds, and then the two run capacitors exploded and burned. I immediately turned off the saw and the power to the circuit, grabed a fire extinguisher and put out the small blaze.
OBVIOUSLY, I SCREWED UP!!! But what was my downfall? Perhaps, one or two run capacitors are a bad idea when the motor driven by the 1ph input has its windings wired in parallel with another 3ph motor to drive it.
Can you experts educate me regarding my mistake and what action to take? Recently, I read someones advise that if two run capacitors are used on different legs that one of them should be about half the value of the other and both sized according to motor hp BUT that does not, it seems to me, to be the source of my problem.
It occured to me that adding the saws inductance to the circuit when it was turned on might have, when combined with the capacitance values, caused a parallel resonant circuit. However, that seems unlikely. Please help. Regards. Ed
