Old Wagner Motor - need help - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Mar 2009
    5,602
    103
    1084
    I removed the message about drawing high current. This guy reports that his motor draws a lot too,
    YouTube
  2. #22
    Jul 2014
    MI USA
    951
    201
    389
    Default AB 609 Sz 0 Manual Starter, Type W heater Element Table #112
    Quote Originally Posted by ClayS View Post
    SAF - the service factor om my motor is 1.25 instead of 1.15, does that make any difference?
    That does make a difference, another 10%. But I would caution against going bigger, unless absolutely necessary. Your motor is old, and intermittent duty, as far as load is concerned. So I would stick to the standard 115% unless it proves to be a problem with nuisance trips.
    Another thing that is possible, is to use the newer style type W heater elements. They might be easier and cheaper to locate used. You just need to remove the solder pot stud, below your old N style heaters with two small screws. The W style heaters, has the solder pot stud built in.
    Here is the table for the W heaters, calibrated for your Sz0 manual starter. This chart is for single phase, and you use it because your old style starter only has two heater elements.
    SAF Ω
    Sample W49
    Allen-Bradley W49 Heater Element | eBay
  3. Likes ClayS liked this post
  4. #23
    Apr 2020
    Indiana
    13
    5
    SAF - was able to find the N27's on ebay, they're on the way, many thanks.
    Thanks everyone for your help
