Oscilloscope and power analyzers?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
    Jan 2003
    Canada
    11,202
    5272
    3355
    Default Oscilloscope and power analyzers?
    Do you guys have any recommendations for a decent but not super expensive way to test the harmonics and wave form on the input lines from the PP?
    Seems all the real power analyzers start at $2000 and go up fast to over $10k. More than I want to throw at it.
    Would the cheaper $200 to $300 1 or 2 channel handheld oscilloscopes be any good for this?
    thanks
    Apr 2019
    UNITED KINGDOM
    14
    As far as I know oscilloscopes need special probes to read large voltages or you need to take a feed and reduce the voltage to read it using an oscilloscope.
    I wanted to do the same thing i looked and just walked away shaking my head not wanting the angry pixies loose on my equipment or me, I am told once the magic smoke is released it's impossible to get it back in.
    This is a video of what you want - there is no telling how it's done I am sure some of the smart peeps here could explain or give a diagram on how to do this
    YouTube
    Jun 2012
    Davis Junction, Illinois
    152
    45
    23
    Rent what you need:
    Rent Test Equipment | Buy Test Equipment | ATEC Rentals
    Test Equipment Rental, Test Equipment Lease - TestEquity
    Which standards are you going to test to, and what are you going to do with the information once you have it?
    Feb 2004
    peekskill, NY
    24,303
    4449
    If you want to test the harmonics at the INPUT side of the unit, it will either be line-to-line
    or line to ground. Both those measurements might be interesting.
    In the first case you will need a two input scope with the ability to difference the two input
    signals. Second case really only a single input scope.
    Because the peak voltages (what the scope actually displays) will be quite high, a 10X probe
    is not sufficient. You will need at least a 100X probe for most scope inputs which are
    typically 10 or 20 volt full scale.
    I suggest at least a 100 MHz bandwith unit, preferrably 500 MHz or even 1 GHz to see what's
    reallly going on there.
    Standard disclamer: voltages ARE lethal in the areas you will be poking around it. If you don't
    know what you are doing, maybe don't.
    Jun 2012
    152
    45
    23
    A power analyzer has 4 voltage connection probes and 3 current sensors. It will have some scope like functionality. I wouldn't bother with a standard scope. Define what you want to know before you start buying/renting and measuring, I can guide you along.
    Nov 2004
    Webster Groves, MO
    7,210
    1808
    3277
    I use a Tektronics 453 that is considered ancient but it works as well now as it did when new. I do have to be careful about grounds. You don't need a super wideband scope for 60 cycle work. The harmonics are mostly multiples of 60 and most are well within the range of almost any scope. I have used the 453 in the last few days, first looking at RS232 spurious signals and then on the waveform of a saturable reactor used to limit current in a mag base drill.
    There are countless oscilloscopes, both CRT and handheld on EBAY at low prices.
    Bill
    Jun 2012
    152
    45
    23
    You really need current probes to get a good sense of what is going on.
    Feb 2004
    peekskill, NY
    24,303
    4449
    "...test the harmonics and wave form on the input lines from the PP? "
    Current probes not needed. Frequencies are a LOT higher than 60 cycles.
    Excuse me. Hertz.
    Mar 2011
    Geneva Illinois USA
    6,114
    2575
    2375
    As noted, define what you want to measure and what you want to use the information for before proceeding. Are you looking just for power factor type stuff or harmonic distortion and Fourier analysis? Do you want to be able to record the data and do a computer analysis? Then there are spectrum analyzers.
    Using conventional lab type o-scopes on power lines can be dangerous. There are special scopes and plugins that are differential and isolated from ground. Another approach is to use instrument transformers for both current and voltage.
    If you want phase angles you will need at least a four channel scope (I don't know of a 3 channel).
    Tom
  10. Likes Archer120x liked this post
  11. #10
    Mar 2011
    Geneva Illinois USA
    6,114
    2575
    2375
    Quote Originally Posted by jim rozen View Post
    Excuse me. Hertz.
    You have just identified yourself as being an OF(old fart).
    Tom
  12. #11
    Jul 2007
    UNITED KINGDOM
    4,755
    2511
    2308
    In the 'old days' (1980's-1990's) you would use a Hewlett Packard harmonic analyzer to show the harmonics in the waveform. Norma power analyzers (bought out by Fluke) now do the same function plus high accuracy power measurements, which was their original forté. I've used both in the field but as you say, they come under the 'super expensive' category. There are digital oscilloscope modules for adding to a PC that have FFT software add-ons readily available via ebay and amazon. Have a look around to see what you need.
  13. #12
    Nov 2004
    Webster Groves, MO
    7,210
    1808
    3277
    Excuse me. Hertz.
    They are cycles, kilocycles and megacycles, etc. Just as there is only one "The War".
    Bill
  14. Likes JST liked this post
  15. #13
    Jun 2001
    St Louis
    17,872
    1804
    2984
    Excuse me. Hertz.
    If he wants "harmonics", the frequencies will not be that high, and most any decent 'scope would show them.
    The real problem is that a 'scope does not give much info about harmonics. Some digital scopes will.
    Also, scopes such as the 453 are not isolated, so they are a good bit more trouble to use off-ground. using differentially helps, but the probes have to be adjusted very well or the results will be way off. Some of the digital scope will also have inputs that are isolated from ground and each other by something from 600 to 1200 volts, which is what you want. There you may be able to clip one suitable prove right across the power line.... check specs before you do that though.
    A power analyzer, such as Fluke and others produce, will be better suited to the job
    If he wants EMI range info regarding some product or piece of equipment, then using a LISN (line impedance stabilizing Network", with suitable spectrum analyzer, would be appropriate. But that does not seem to be what he really wants.
  16. Likes Archer120x liked this post
  17. #14
    Jan 2003
    Canada
    11,202
    5272
    3355
    Been reading a bit more, mostly looking at figuring out Total harmonic distortion, and which hz are the worst, and ideally the strength of it?
    One reason being to regularly monitor the filter caps performance and catch it if and when THD starts to rise (I assume it should?)
    Other, if I start adding anything else for more filtering like a line reactor or other caps, I'd like to see if it is making a difference and where.
    I'm kind of assuming THD it probably a common basic calculation for most oscilloscopes but can't seem to find it mentioned in much specs so far.
  18. #15
    Nov 2004
    Webster Groves, MO
    7,210
    1808
    3277
    Quote Originally Posted by TDegenhart View Post
    Tom
    I do it all the time with one or two channels. For one, put it on the reference trace using the external trigger, not the signal to control the sweep. Adjust the sweep and trigger to display one sine wave with the beginning, center and end zero crossings right on the marks, then move the probe to the other signal and count marks.
    Bill
  19. #16
    Dec 2010
    Mifflintown, PA 17059
    1,755
    20
    197
    I've picked up a few scopes on ebay, I have a dual trace and quad by Tektronics, Also have a Dual beam Tek., has 2 guns not chopped trace. But my favorite is an Hitachi (think I spelled it right) quad trace really nice scope made in Japan. Input voltage is higher than Tek. scopes, if my memory is correct 400VAC. Also picked up quite a few plug-ins and high voltage probe. Check ebay they might have just what's needed.
  20. Likes SND liked this post
  21. #17
    Dec 2013
    Vermont, USA
    452
    6
    112
    I can't tell where the OP is located within Canada (remote, suburban???) but if anywhere near population centers, if you can find a location and date for any sort of substantial sized 'hamfest' (amateur radio flea market/ swap meet) or even get connected with a network of hams, older, nicer CRT scopes sometimes go for prices approaching 'free if you take it.' I currently 'host' several Tek scopes that were cutting edge 50+/- years ago and that I'd literally give away to a good home, and that I have only because I rescued them from a worse fate that they didn't deserve (and they are redundant to other scopes I have and that I'm more inclined to keep)
  22. #18
    Mar 2011
    Geneva Illinois USA
    6,114
    2575
    2375
    If you want continuous power monitoring, consider a PC with data input cards and some software. I used to do this my last job, use an optoisolator, DATAQ or similar AD convertors and software.
    Do a google search using data acquisition and/or software to get started. National makes vary good stuff, but expensive.
    Tom
  23. #19
    Dec 2013
    Vermont, USA
    452
    6
    112
    Tom
    Some time back someone on here had referenced some relatively new and affordable, but pretty capable, power monitor that may have even used something like a smartphone or a bluetooth connection to a computer. I remember being intrigued and impressed with what it was capable of in relation to what it cost. But at the moment I cannot remember details.
    This looks intriguing but I can't seem to see what it costs or how to specifically purchase the hardware
    OpenZmeter | oZm
  24. #20
    Jan 2003
    Canada
    11,202
    5272
    3355
    I'm starting to lean toward an AEMC 407, its a clamp meter with some THD capacility, and with the software it appears it may display to higher harmonics than 25th. good thing is its rated for this type of utility work, and not too much $$$, about as much as decent entry level oscilloscopes, but all those I looked at so far don't appear to give a THD%, though they have FFT function.
