AndyF
Stainless
- Nov 3, 2003
- Phelps, NY, USA
The title says it all. I have a 15" Harrison lathe with what is supposed to be a 5hp 2 speed motor. I can't get at the data plate with-out removing the motor from the lathe, so I am taking the seller at his word that it is a 5 hp motor. My Rotary Phase Converter is an older Ronk unit and is rated to start a 5hp motor and run up to 10hp in motors. The lathe starts just fine in low speed forward or low speed reverse. When I try to start the motor in high speed forward or reverse and do not have anything else running off the phase converter I get a fair amount of noise from the phase converter and it slows down - almost as if the load is too great. It will eventually spin the lathe motor and itself back up to speed, but it takes a few seconds. If I have another machine running when I start the lathe, there is less noise from the converter, but it still bogs down a little as it starts up the motor.
What is going on here? Are there any easy (read cheap) fixes?
