Phase Converter Buzzing
Results 1 to 5 of 5
    Mar 2012
    Western USA
    24
    Default Phase Converter Buzzing
    I've just finished putting together a 10HP phase converter using an American Rotary panel and a self supplied idler motor. The idler motor is making a buzzing noise when there's no load on the circuit. As soon as I apply a load it goes away. See the video in the link below.
    VID_20200601_113019_LS.mp4 - Google Drive
    American Rotary support was great until they realized I was using my own idler motor, then they told me to buzz off (ha). Below are the voltage readings between legs.
    Loaded__________Unloaded
    L1-L2: 238_______L1-L2: 239
    L1-L3: 233_______L1-L3: 250
    L2-L3: 230_______L2-L3: 232
    Does anyone have any idea what's causing this and how I can resolve it? Thanks in advance!
  2. Likes johansen liked this post
  3. #2
    Aug 2014
    bainbridge island
    1,258
    261
    297
    Quote Originally Posted by Grenade View Post
    remove some of the run capacitors until you see that 250 volt number drop a bit, or just ignore it. 250 volts no load is not too high.
    you can then take those capacitors which were removed and move them to the load so they are only switched in when the load is turned on.
    Mar 2012
    Western USA
    24
    Quote Originally Posted by johansen View Post
    I'll give it a shot. Is it likely high voltage on one leg is causing the buzzing problem I'm experiencing?
    Aug 2014
    bainbridge island
    1,258
    261
    297
    motors buzz because the core is saturated and the magnetic field is escaping the stator core and causing the rest of the motor casing to vibrate.. typically sheet metal.
    Jul 2017
    CANADA
    Alberta
    77
    23
    [QUOTE=johansen;3560855]remove some of the run capacitors until you see that 250 volt number drop a bit, or just ignore it. 250 volts no load is not too high.
    you can then take those capacitors which were removed and move them to the load so they are only switched in when the load is turned on.[/QUOT
    Interesting !! Caps in the load. All three phases?? Or just generated phase?
