phase converter quieter when vertical...
Results 1 to 14 of 14
    Aug 2019
    Alabama
    42
    11
    5
    Default phase converter quieter when vertical...
    I have a homebuilt RPC. It is a 10HP Baldor motor running 1760 RPM, using a start capacitor and run capacitors. It runs my mill, lathe, surface grinder just fine.
    However it is noisy. Compared to a commercial unit, very noisy. I have been messing with insulation and isolation. And on a hairbrained whim I set the motor on its butt so the spindle was vertical and it was *significantly* quieter.
    Two questions:
    1) Is this indicative of bad bearings?
    2) Assuming sufficient clearance for airflow, is there any reason I can't just run it in the vertical orientation permanently?
    I haven't cracked the case on the motor. The heritage of the motor is unknown but it is rust free and appears in good shape. No real runout and spins up like a champ. $50 on Craigslist from a guy who said he was saving it for a project that never happened, pulled from working service.
    thanks
    philip
    Virginia
    30,393
    7561
    9504
    Quote Originally Posted by hahnpv View Post
    Two questions:
    thanks
    philip
    Well. dunno what TYPE of motor your idler is, but MY idler is an "Open, Drip Proof" Fan-cooled Weg.
    Given the intake grill for the fan is pierced holes in the ass-end, s**t metal, sitting it on its "butt" would prevent air reaching the fan, so yea, quieter.
    Hafta say that's in the same league as stopping PMS by getting the gal pregnant.
    Eventually, there are OTHER consequences?
    Aug 2019
    Alabama
    42
    11
    5
    It is propped up to allow for airflow. Still quieter.
    This motor: M3313T - Baldor.com
    -philip
    Virginia
    30,393
    7561
    9504
    -philip
    Just a guess then, and at two things. Audio industry background, Deaf old 'nam vet, I own and rely on a cheap "Sound Pressure Level" meter for quieting-down my gen set and such - not on my own damaged ears. Bad days and good days, but there's lots of stuff i can't hear, period, some of it hazardous.
    - Is it ACTUALLY emitting less noise? Or is it simply projecting the same amount in a direction away from your ears - attenuated by the time it comes back to you? No foul. A benefit is a benefit. You can use that. Perhaps several among us can use that.
    - do the bearings permit a slight end-float when the shaft is horizontal, and load onto only the one when vertical? That's OK, too IF the motor is listed for continuous running all orientations, or at least vertical operation.
    Not ALL are so rated, believe it or not. Some will suffer reduced bearing life.
    That data may be off in the maker's "family" of a given motor's specs, not necessarily shown on each individual motor IN said family poop-sheet.
    Even so . bearings are cheap enough. So long as replaced BEFORE they hard-fail, not after!
    2CW
    Jul 2014
    MI USA
    944
    200
    388
    Default Toning Down A RPC Idler
    It's likely, on a used motor that your bearing grease is dried up, and they are running dry, metal to metal. All the grease has been pushed to the side, and is no longer flowing. Turning the motor on end puts a bit of axial thrust on the rotor, and allows the bearing balls to touch some of the side grease, for a while.
    Putting in a fresh set of bearings, and some vibration isolator feet, would go a long way to keeping the noise down, for the long haul. The starting torque when standing it on end, may cause it to roll over, or twist around.
    From the motor tag, in the link you provided, these are the bearings you would need, lower end units, but you don't need high quality ones, for an unloaded motor, just ones with fresh grease. $25 bucks would get you fresh bearings and vibration isolators.
    Bl Radial Ball Bearing, PS, 35mm, 6307-2RS 6307 2RS/C3 PRX | Zoro.com
    Bl Radial Ball Bearing, PS, 30mm, 6206ZZ 6206 ZZ/C3 PRX | Zoro.com
    Zoro Select Vibration Isolator, 60 Lb Max, 5/16-18 2NPG3 | Zoro.com
    SAF Ω
  6. Likes hahnpv liked this post
    Sep 2006
    Sacramento County, California
    3,917
    2455
    1389
    I bought a NOS Boston Gear 5 hp TECF motor on eBay for my first RPC. It was very noisy when first started. It also squealed from time to time. I ran it for a while and also noticed that it was getting very hot.
    Upon disassembly (four long, thin bolts) I discovered that the sealed bearings were Ka-Ka. A trip to the bearing store and a few minutes with my bearing puller and all was well. It's now not only reasonably quiet, but actually emits rather a pleasant sound and runs at a proper heat.
    Check your bearings.
  8. Likes Hopefuldave liked this post
  9. #7
    Jun 2006
    784
    691
    97
    Two questions:
    Maybe.
    Do you have a bearing puller? Replacing motor bearings is usually not too hard.
    As long as your fan is working and cooling it.
    You could mount standoffs to get clearance for airflow, but honestly I’d try to figure out what the noise source is and rectify it.
    Checking/replacing bearings is not a bad idea.
    Is the motor well balanced?
    Does it have a shaft? Keyway? Balance it or cut the shaft off.
    Are the fan blades all there? Bent? Balanced?
  10. #8
    Oct 2004
    Iowa
    3,212
    77
    449
    It's not unusual to have a horizontal motor generate less noise in vertical operation, and all the above notes about grease and bearings are true, but here's a big reason why it happens:
    When the plane of the motor's rotor is horizontal, and the motor is sitting on a flat surface, that surface becomes a 'speaker', converting motor vibration into sound pressure. Doesn't matter what the surface is, if it's getting vibration transferred from the motor, you're gonna get noise.
    By standing motor up on end, rotor vibration occurs on an axis perpendicular to the mounting surface, so motor vibrations are not directly coupled to that surface. The end result, is much less amplitude from the flat surface, hence, less noise.
    The problem you'll run into with running the motor vertically, is that the motor's shaft bearings are not designed to tolerate loading of vertical suspension.
    IF you choose to mount it vertically, one way to accomodate that, is simply to replace the bearings, but to use a bearing rated for lateral load, and install it in proper orientation to accept the vertical load. Another way is to put a thrust bearing on a fixture on the end the shaft to accept that end-loading.
    After all, the rotor is not doing any real loading... you're just supporting it against gravity.
  11. #9
    Virginia
    30,393
    7561
    9504
    Quote Originally Posted by DaveKamp View Post
    Thanks, Dave!
    Thank you, double, hahnpv, for bringing it to the top of the office in-tray!
    Wish I had seen this several years ago. Or figured it out meself. As I SHOULD have,
    What with having a PAIR of the highest-grade anechoic chambers and Bruel & Kjaer test gear available as weekend playtoys. Designing speaker enclosures with a 20+ patent holder as mentor?
    Brethren? Yah know when we go a'scouting for bargains on 3-P motors to use for idlers?
    How many among us have given surplused vertical shaft PUMP motors a miss?
    Already equipped just the way we need them. Quite often going begging in the used or NOS market as too specialized for general-purpose needs.
    Damn. Cudda saved a few sheckels and had a quieter RPC into the deal?
    Sure got THAT shot bass-ackwards!
    UPDATE:
    "Curses. Foiled again."
    Yazz. Vertical shaft pump motors were found at very, very, favourable prices per HP.
    Sadly, I do not need, nor can I feed ... 500 HP.. 150 HP... 100 HP .."idlers".
    Back to the drawing board...
  12. Likes wheels17 liked this post
  13. #10
    Aug 2019
    Alabama
    42
    11
    5
    This of course is very true.
    The other test I did was place the motor hoizontal to the ground, start it up and then press against the end of the shaft with a 2x4 applying some load much like gravity would if it were vertically oriented, and again it got quieter. Maybe this is indicative of the bearings being an issue.
    I'll try giving the bearings an inspection / replacement.
    thanks all
    philip
  14. #11
    Mar 2009
    5,586
    103
    1079
    There should be a wavy spring washer on the shaft that exerts a force on one of the bearings. Usually it is between the back shell and the back end bearing.
    There might also be a straight washer next to the wavy washer. A few times I increased the thickness of my straight washer by stacking some smaller washers
    together and assembling the motor back together and testing. A few thousands more in thickness made a difference for quieter operation. Then I machined a new
    washer with the new dimension.
    If the bearings do not have rubber seals then you can soak them in lacquer thinner and dissolve the old grease. Then palm in new grease. That means you can
    hold the bearing in your palm and force new grease with your fingers. You can also use a bearing pack tool which doesn't cost much or make one.
    RPC motors run quieter and vibrate less when they are balanced correctly with the right amount of run capacitors. That is when the target motor is powered.
    When the RPC motor is running by itself then it should be louder and vibrate more because you would have balanced it when running a target motor.
  15. Likes hahnpv liked this post
  16. #12
    Mar 2009
    5,586
    103
    1079
    Two questions:
    I had done this years ago with a 5Hp motor and noticed that the noise was reduced. It does not appear that the bearings would wear evenly and that
    if the orientation was changed to horizontal I might hear more noise.
    Instead I use a small torch flame on the cases before unseating the bearings.
    Only use totally sealed bearings.
    Do a static balance of the rotor.
    If this is a RPC motor the balance capacitors are added to get 1-2% voltage change from phase to phase.
  17. #13
    Sep 2006
    3,917
    2455
    1389
    The best thing that I did to quiet down my RPCs was to use rubber pads under the frame. Although the motors were fairly quiet, the rubber mounts helped to further quiet them down.
  18. #14
    Aug 2019
    Alabama
    42
    11
    5
    Quote Originally Posted by rons View Post
    I took off the back end and this is correct - wavy washer to apply axial load. The bearings were essentially dry and noisy when spun by hand. There was some blue grease off to the side - zerk feeding to feed grease in to the side of the bearing by the wavy washer. Palm greased and reinstalled for now.
    I need to remove the sheave before I can assess the other end, and then I'll likely order new bearings.
    RPC motors run quieter and vibrate less when they are balanced correctly with the right amount of run capacitors. That is when the target motor is powered. When the RPC motor is running by itself then it should be louder and vibrate more because you would have balanced it when running a target motor.
    Once I get rid of the mechanical noise, this is next. Thanks,
    philip
